Augoose
- Mar 21, 2010
- 1,232
All,
the starboard side steel hinge for the fiberglass engine cover has broken away from the surrounding fiberglass. This cover weighs a ton and is supported by twin 120 lb gas shocks on either side. When I got the boat the port side hinge was completely missing but I already made a new one. My plan now is to remove the deck pad and take the cover itself to someone who can re-glass both corners. Once its back from the glass shop I'll then fabricate two 1/8th" steel pans to sit inside the newly fiberglasses corners. That way the load on the hinges is distributed across the new fiberglass corners and into the new steel pan instead of just on the fiberglass like it used to be- the fiberglass will be sandwiched between the existing hinge and the new pan.
Does anyone have any other suggestions?
Any idea on an approximate cost for the fiberglass repair?
