Hi all,
First I'd like to apologize for my poor english as I don't practice it a lot here in France.
So, my problem is that I got a 1999 Evinrude 8hp 4 stroke (E8RL4EEM) and the first time I used it (salt water), it was running fine but overheated and stalled. I don't know anything about outboard engines but since then I try to read and understand as much as I can.
I unmounted almost everything except the head. I cleaned everything, changed the waterpump, the thermostat, a bunch of seals, the gearcase oil, motor oil etc...
Before going out using this boat I'd like to be sure that it's cooling fine and I don't understand how works the thermostat.
From what I've seen after unmounting the engine is that the water comes from the water pump, goes to the head via the exhaust part, goes to the pee hose (funny, the french word is the direct translation
) and to the engine. It goes out of the thermostat via a hose right in the middle engine section with the exhaust.
My questions are:
How could I check that my cooling system is working properly now?
(the flow getting out of the pee hose pretty strong now so I guess the water pump is good now)
If, engine running, I remove the hose coming out of the thermostat (the one going in the middle section) there's water flowing all the time (engine cold and also after 15min) is it normal?
What is the water circulation in this engine?
Thanks for reading,
Pierre.
My questions are:
Thanks for reading,
Pierre.
