Re: 1999 Force 40 not streaming water
i dont believe that all of these motor stream water from the relief holes... i have an 85 force and a 125 force and both of them just mist a little water out the exhaust relief holes when im running wide open... very very little water comes out of mine any other time. i would suggest getting a good temp guage and take it on the water and watch your temp if it doesnt get very high just go with it... im not sure if the 40 hp has a tell tale but if it doesnt you should be able to install one... there is a sticky in the top of the forum that shows you how to install one... see if it applies to yours thats the easiest way to tell. I wouldnt be concerned if it wasnt spraying out the relief holes, just my opinion.
also muffs is a bad way to test an impeller the only sure fire way is to back it into the water... leave it hooked to the trailer if you need to, you just need to submerge it to get a good flow of water.
