Heywire77
- Jun 19, 2012
- 101
Please help I removed my lower unit and replaced water pump and my son turned the shaft on the lower unit were the shift rod linkage hooks to and I don't know we're to turn the rod all the way right or left with the controls in neutral ? That way when I bolt the lower unit on don't want the control in boat to be in neutral and the lower unit be in wrong position and it be in forward or reverse or break something? Please help, also I can turn that shift rod all the way right or left and then when I turn the prop by hand it will click noise with the prop turning forward and engage with turning backwards or reverse and either way I turn that shift shaft it does the same thing clicks turning prop forward is that right also? Thanks
