1999 johnson 250hp oil injection removal???
adm1476
I removed / disconnected the oil injection on my 1999 250 johnson. I run premixed fuel. this eliminates the risk of a blown engine due to injection system failure. However now I get a warning light and that damn alarm screeching. Is there a way to set it up to where the alarm will not go off? It goes off when I first start it, then again randomly while I am running.
flyingscott
What is the model #. If it has VRO unplug the pump harness to eliminate alarms
adm1476
It is the newer version on the vro system. I already unplugged the tank but I don't see any other wires coming out of the pump.
jakedaawg
He is stating "oil injection". Probably need to make sure this is not a ficht.
Faztbullet
If its a ficht it wont run long!!!!! Then this will become a rebuild post!
adm1476
Sorry for being off so long. I have it fixed. It is not a ficht. Someone plugged the vro pump back in, and I did not realize it. Unplugged and the problem is solved.
