1999 johnson 90 hp main in line fuse
brodius
My 2 stroke outboard that I bought is missing the fuse for the main in line starter and power tilt and trim. Can anybody tell me the specs on with fuse to install???
Just bought it ??-----Motor is a 1998 model crossflow.-----Compression test should be done for future reference.----Post your numbers.-----Don't spend any beer tokens till you do the inspection.
brodius
compression test was done before purchase. All reading were at 120 PSI. What about the specs for the spark plugs for this motor?
Sparkplugs last for years and years on this 1998 motor.------Best to spend money and time on other things like a new impeller in water pump.-----If oil injection is in service a new oil filter and oil " consumption test " should be done !!
