1999 Johnson lower unit removal
christiandk
Hi guys,
Just working my new old 35 hp Johnson. Want to replace the impeller but cant get the lower unit to drop. yes I have removed all 5 bolts and broken one :(
Where do I disconnect the shift linkage?
cheers from Copenhagen,
Christian
Remove the water intake screen.-----Scrape paint off the upper shift rod.--------Then loosen the coupling nuts.---Caution do not turn the upper shift rod.------Slide the fitting up the upper shift rod.-----Remove the black plastic keeper.
christiandk
Thanks man,
wanted to post pics of wgere I am now but cant do it.
thought that it was much easier to replace the impeller on the 35 Hp
happy easter,
christian
christiandk
It was easy!
the impeller was wared so good thing I took it apart.
Unfortunately the woodrof key was missing so I cant come any further untill I get a new key.
Cheers and thanks,
christian
It is not a woodruff key.--------The key is typically found under the water pump plate when it goes " missing "
