1999 marada xrt 2102 5.7 mcm efi. not getttin gas or spark
1999maradaxrt
1999 marada xrt 2102. ran fine three days ago went to start it yesterday now its getting no spark or fuel. you used to be able to hear the pump for couple seconds now you cant at all.any help would be apperciated. i cant find wiring diagram or fuse schemtaics or anything
Bt Doctur
If there is a black metal box port side of motor mounted on the riser , should be 3 fuses in there
1999maradaxrt
yes bt doctur there is three fuses and some relays all the fuses good in there. then theres a circuit breaker on the front of box its not popped nor the other one. any other ideas why wont no spark or fuel
Bt Doctur
well ,no 12v power comes to mind. see if there is 12v at the CB and the orange wire at the alt
Do the gauges come alive?
Bt Doctur
locate the coil plug from the harness not the engine side .should be a red wire or a red/stripe wire . unplug from the coil and with the key on test for 12v at the red or red/stripe wire. If no power trace back
What coil, a standard round one or the small squareish one
