1999 Mercury 115 sparkplug advice needed
wdbcov
People, people, people..... i have installed new NGK plugs in my 1999 Mercury 115.....went to the lake, the motor idled rough, sputtered taking off but finally smoothed out at WOT. This is unlike the motor performed prior to changeing the plugs. While on the lake I changed back the the identical plugs I removed, and the performance was back to normal.What did I miss??? I noticed oil on the new ones I removed.... i did not gap the plugs.... I think this is the problem but want to find out what are the best plugs to install, and the gap.... any help would be helpful and apprieciated.... its cold in GA... and I am getting Stir crazy and working on everything I can.
Faztbullet
Re: 1999 Mercury 115 sparkplug advice needed
Are they the same numbers??
wdbcov
Yes sir...all numbers are identical.... thnaks for responding.
1nebel0
You got a bad plug...pull one wire off at a time and see which cylinder is not contributing...If you have an rpm meter it is easier to see the numbers....
wdbcov
Will try to identify this weekend.... thanks for the reply!
Chris1956
Normally the spark plug manufacturer will identify the plug number and gap for a particular application. I recommend you verify you have the right plugs, and gap per specs, as factory gapping could be incorrect.
