199x 70hp johnson
dieselcat
I am going to look at a 1990's johnson 70 hp outboard this weekend with possibility of purchasing it and am going to do a compression check.can someone tell me what numbers I should be looking for on compression?
Thanks in advance
boobie
Re: 199x 70hp johnson
No more than 15 psi variation between cyls. Post back with your #'s.
dieselcat
Ok boobie im going to look at motor now and am not gonna have the luxury to post psi numbers so can u tell me how low of compression is to low.the guy told me when he checked it when he purchased it that it had 95-100 psi per cylinder. ..
boobie
His #'s sound okay but what are they now ?? You can rent a compression gauge from most parts houses,
dieselcat
Ok checked it,it seemed good to me top cyl 98 mid cyl 94ish bot cyl 98
JB
Gauges, conditions and techniques vary too much to put criteria on psi, but since there is no variation from cylinder to cylinder it is the spread that matters. Done this way http://forums.iboats.com/engine-frequently-asked-questions-faq/compression-test-jb-391323.html the spread should be 10% or less.
It is near impossible for three cylinders to go bad by the same amount at the same time so don't fret about psi unless it is down to around 70-80psi.
EDIT: You posted while I was typing. Those numbers are fine. :)
dieselcat
Thanks for the speedy feed back,I really appreciate it!
