Hello all. I bought my 1st boat a few weeks ago. I have a 135 HP Mercury Black Max motor. Appears to be 70s model. Replaced all grounding straps and positive cable from starter to solenoid; I think. Replaced battery cables. Manual choke and electric choke are not wired or connected. Previous owner used flat head screwdriver to start. Even putting starting fluid in the carbs (3) it does not fire. There is a push button on the dash but is not wired. Going to replace plugs and wires this weekend. Will most likely replace most of the smaller wires this weekend also. I have muffs. Do I start the hose first or the motor first? Does the push button matter? I choked the motor by hand and it still would not fire. I am not sure where the spark or mech advance are set or how to find out. Not sure its important. Also will probably check the points are set up properly this weekend. Thanks in advance for any help figuring out how to start this thing.
Bill
Bill
