1st time lower unit removal, what is this part and where does it go?
Karla45
Re: 1st time lower unit removal, what is this part and where does it go?
OKay now I have the housing on and am putting water pump gaskets and plate on. Do i need to put anything on the gaskets like rtv or somehting. I read something about putting oil on gaskets or do I just leave them like they are?
jerryjerry05
Nothing.Just put them on.J
Karla45
That is what I thought but I wanted to double check. Now here is my problem I am having a pretty hard time getting the impeller to go into the water pump housing liner. Any suggestions I have put triple guard grease all in the liner but this is not helping at all. If I push down really hard while turning could i possibly tear the rubber. It seems like the liner would cut into it.
jerryjerry05
Put the impeller on and as you push the housing down, turn the drive shaft either way.It will just slide down and fit into the housing.
After it starts the blades will turn the right way.J
Karla45
Okay I thought I had to be careful on which way I turn the impeller to make sure the veins were going the right way. You make it sound very easy and I have watched videos where it looked much easier to get the impeller in. It just seems way to big but I am going to try again.
Karla45
okay I got it on. Vaselilne works better. Thanks for help.
Karla45
Well I am down to the wire but now I have a problem. My water pump has 5 lock nuts that hold it in place. The 5th nut that goes in the front by the water tube just keeps turning and turning. I can tell it is the nut that is stripped. Any suggestions on how to get the nut off? Here is a picture. Also, is it okay to just buy a lock nut at home depot or something like that or do i need to buy the part that from mecury dealer, not sure if has special qualities out side of being stainless steel.
Karla45
Tryed vice grips while pulling up but not enough clearance between the nut and tube to be able to really get full turns. AM thinking of getting one of the smaller bolt cutters.
Karla45
okay finally got the nut to come off. I bought a 10-32 stainless steel nut from home depot. The only difference I am seeing is that the original is not as tall as the one from home depot, which leads me to the question of torque, does this make a difference, I notice that the stud is not flush with the top of the nut like the original that was shorter(in height).
I am also a little confused on torque values for the water pump nuts. The reason I want to tighten to torque is because the person before me had tightened the nuts too much which warped the water pump housing and made it crack.
I have a 1989 85HP single exhaust, 2 piece driveshaft
On the pump itself it has imprint of 40-50 inch pounds for 1/4 nuts, then it says 15 inch pounds on #10 nut.
When I look in the manual it gives specific torque values for 85HP single exhaust 2 piece drive shaft as 70in pounds for long studs(1/4-28 nut) and 40 inch pounds for short stud(#10 nut). Then if I look at the 90hp, dual exhaust, 2 piece driveshaft it shows 50 inch pounds for long stud and 15 inch pounds for short stud which almost matches what is imprinted on pump housing but I have 85hp single exhaust, not 90HP dual. The reason it is confusing to me is that I am not sure if I am supposed to tighten the 4 1/4 nuts on long studs to 70in/lb(manual 85hp,single exhaust, 2 piece drive shaft), 40in/lb, or 50in/lb(manual & imprint on pump), not sure why they would say 40 to 50 in/lbs(specs for 90hp,dual exhaust in manual 50 inch/pds) on the water pump instead of just one value.
On the short stud the manual says 40in/pds for 85Hp single exhaust, 2 piece driveshaft, whereas the imprint on pump says 15 in/pounds and the manual says 15in/pds for 90HP dual exhaust. I do not want to under tighten but do not want to over do it either and their seems to be a big difference between 15in/pds and 40 in/pounds.
jerryjerry05
Your gonna drive yourself nutsy if you try to tourqe everything to spec.
The only real tourqe needed is the nut on the flywheel and the head bolts.
Tight enough that you can't undo them by hand yet tight enough they won't come out on their own.
Karla45
Yeah, I started to get frustrated with it and just decided to not worry about it.
Karla45
wanted to thank everybody for all the help. My lower unit is no longer leaking oil thanks to you guys.
pnwboat
I think that you certainly deserve some credit for not giving up! Anyways, glad you finally got everything squared away.
Karla45
Thanks! Now I am ready to do some fishing! Lake Fork here I come!
