Need help....
I have a 91 4 winns with a 2.3 OMC Ford. It runs good but for the past 3 seasons it has had a dead spot in the throttle. I can push through and it will go. WOT is about 5000 RPM. Just cant ease the throttle up, it will sputter and die if I don't give it more throttle. I have rebuilt the carb, changed the dist cap, wires, plugs, the anti siphon valve and the fuel lines from the gas tank. It's been in the shop 3 times and they can't seem to find the problem. It's in the shop now and they are changing the points and condenser. It only does this under a load. Any one have ideas where else to look. The shift assist has been disconnected and no change.
