2 fuel lines
licorice
I recently purchased a 6 hp merc for my kicker as I was mounting it on the boat I noticed there is a water separator for the 120 merc or Chrysler I already have on. It has 1 port in and 2 ports out the 2 ports are sealed by allen wrench screws. Is it possible to run another fuel line to supply my kicker they both are 2 strokes. tx Licorice
CoffeeHound
Re: 2 fuel lines
Yes to using the tap off the fuel seperator .
It is an added bonus to the kicker being a dependable back up when needed,
unless your main motor went down because of contaminated fuel . Do your
inspections with special note to the seperator and enjoy the knowledge that your kicker
is ready for duty at a moments notice !
licorice
Re: 2 fuel lines
awww tx guys I thought it might be possible but this is an added bonus!! Will get to work on it as soon as possible and will keep ya all updated. Jerry
jerryjerry05
Re: 2 fuel lines
One thing!!!
You need to make sure both motor have been pumped up.
If both aren't,you can draw the fuel from the kicker and start sucking air into the other.
Maybe a small shutoff or a quick disconect.
