Re: 2 or 3 cylinders, does it really matter?
<br /><br />
<br /><br />
<br /><br />
You're just repeating what I've already said here...Declared power is what the manufacture "calls" their motor, such as a "150" and the rated rpm has to be in the middle of the full throttle operating range. Most engines have a 1000 rpm operating range, such as 5000 to 6000 rpm, with the max horsepower at 5500 rpm. Some engines only have a 500 rpm operating range such as 5500-6000 with max power at 5750 rpm.
And here...By Forktail - Their rated (for sale) power must be the full throttle power at the declared speed (at prop shaft), based on the corrected power on one or more engines. For example 150 HP at 5500 rpm.
By Forktail - That declared speed must be the mid-point of the full throttle speed range recommended by the manufacturer for prop selection. For example 5500 rpm is the mid-point between a recommended 5000-6000 operating rpm.
Your statement that a 150 hp outboard can have an "output of as high as 165hp or as little as 135 hp and still meet the industry standards" is wrong. It's wrong because you are deviating the declared (prop shaft) power 10%, not the corrected power (engine dyno).<br /><br />Outboard manufacturers declare their power at the prop shaft per Section 6. Thus, ICOMIA Section 6.2 clearly states, "...the highest power within this range does not exceed declared power by more than 6%. If the highest power exceeds declared power by more than 6%, both powers shall be stated for that model"<br /><br />So in your example, the 150 HP outboard would also have to be declared a 165 HP model (dual rated), since the declared power deviated more than 6%. Clearly, the maximum HP a 150 HP outboard could have would be 159 HP (additional 6% of 150 at propshaft, assuming corrected deviation was not exceeded to do it). It's not that tough seahorse.<br /><br />BTW 10% deviation only applies to a certain HP class of outboards. And the Coast Guard wouldn't be to happy if your 150 HP rated boat actually had 165 HP on it.<br /><br />Corrected power (on outboards) cannot deviate more that 10% each way from the declared power. (ICOMIA Section 7)
A repeated spin of what I've already said here...High performance models such as Yamaha's Vmax and Evinrude's HO series have horsepower outputs at the very top of the 10% limit.
By Forktail - Now you know, in part, why manufacturers can use nearly the exact same outboard for different HP classes. And now you know why some of us like to prop for the top of the RPM range.
Most techs have no clue how outboards are rated. Try asking one next time. It's laughable. And most techs don't bother reading squat.<br /><br />Even you, the master of all, seem to be learning as you go.Most techs know this and the factories put out this information.
