2-stroke maintenance
Busisa
Hi Guys. Got a question, here it is. What does an 100hr maintenance service on a yamaha 200hp 2 - stroke look like ? i would love to know
jhande
Google is your quick friend.
roscoe
PROBABLY ABOUT THE SAME AS IT IS FOR A 4 STROKE, MINUS SOME OIL AND A FILTER.
$200 FOR PARTS, $250 - $350 FOR LABOR.
I WOULD HOPE IT WOULD INCLUDE THERMOSTAT(S),COMPRESSION TEST, FUEL PUMP SERVICE, GREASE, PLUGS, WATER PUMP, GEAR LUBE, GEARCASE SEAL TEST IF LUBE IS BAD.
Well , well-----Can you pull off the bearing on the good hub and read numbers there ?
