Sea Rider
- Sep 20, 2008
- 12,345
Trying to make such an oldie motor to work again as used to do in the good old days. It's a 2 cylinder point and condenser model with a non through exhaust prop. Need the electrical DVA output voltage parameters of the Exciter Coil and the Ohm data for the Exciter & Ignition Coil if someone has both at hand and willing to share this data.
Seems the Exciter Coil is bad as both spark plugs outputs when measured with a bulb spark tester shows a very poor lighting, the upper IC lights with more intensity than the lower one but poorly compared to other Yam motors.
The motor had severe corrosion as seen at left hand area that was restored with welded alum filling There's the controversy that old Yam blocks suffered from premature corrosion, wondering if it's a true statement or cheap BS talk ?
The motor retains its original gasket set, made a compression test and the upper cylinder achieved just 40 PSI after 5-6 hard rope pulls while the lower one achieved 60 PSI, both readings are out of this world. That motor should produce at least 100 PSI output per cylinder. Hope the piston rings are stuck on their respective grooves and there's no need to enlarge both cylinders to install next size pistons and rings. Will tear the whole powerhead soon to find that out.
Happy Boating
Happy Boating
