I took my boat with 1998 200hp EFI Merc. & less than 100 hrs. in to the dealer after being stored for the winter to have him change the water impeller, filters, plugs etc. When I put it away last fall I had fogged the cylinders and left fuel in the lines. Everything was running good and quiet last summer. I had it running for half a minute at home (with water connected to intakes) before I took it to the dealer. It sounded fine at that time, however the cowl was on.<br />After he did the work the dealer called and had me go look at the motor . With the cowl off it was making a fairly loud knocking sound coming from the powerhead. He said that he had checked the driveshaft and it was connected OK. He suggested that maybe a rod was loose or bad bearing on the crank. The dealer suggests installing a new long block as it may be the most economical way to repair the problem vs. teardown and rebuild but he doesn't know what the cause could be. Without tearing it down, any ideas what may be wrong? Could a bearing or connecting rod be the problem? Could a defective spark plug or ignition problem cause the knock?
