2000 18hp nissan outboard
pvanv
What model? Is it OK at all other speeds? Probably NS18E2. When was the carb last cleaned?
wormkiller
The model is NS18E2. The carb has been thoroughly cleaned with fresh rebuild kit. New coil,new plugs,new fuel lines, fuel filter. New throttle arm linkage.
wormkiller
Sonic cleaner , carb spray, compressed air and used torch cleaner to clean all holes. To me carb seem super clean
airshot
Is the throttle properly synced to the carb ?? Do you have a factory service manual ?? After replacing all that stuff, everything needs aligned with each other to function correctly... A manual should give you step by step instructions ...
wormkiller
I tried my best to sync the carb because replace the throttle arm with white roller . I had found it broken. I do have a manual but i dont thank its a factory manual.
airshot
Get a factory service manual and follow it closely. Getting the throttle syc together is critical to good operation !! I found manuals on Ebay or order them thru the mfgr....you DO need the factory manual to set it up correctly !!
