ggundersen3
- Dec 25, 2007
- 249
I'm looking at clean 2000 Bayliner 2050 with a 4.3L Mecruiser 210HP. The boat was maintained fairly well, solid floors, original seats with no tears(Captains seats with large bench seat in back. All seating is in good shape. However, someone installed a reinforcement plate to the floor under drivers seat and screwed it into the floor but when doing so on the right/starboard side the screws came through the hull. They protrude abou 1/4'' to 1/2'. They left it that way and it looks like they used GE Silicone or 3M 5200 to make the screws watertight. It's just above the waterline. Im thinking I could cut the screws off flush with the hull and cover it with white 3M 5200 and all should look and be OK. It's a white hull, so white 5200 wouldnt show much. Advice needed here though.....Did they compromise the integrity/strength of the hull in anyway by drilling though it and installing these screws? Should I remove the screws and just seal the holes with 3M 5200 and not worry about securing that side of the reinforcement plate if the other 3 sides are already screwed in to floor? Any other thoughts? THANKS
