2000 Cruisers 2870 Check Engine light blinking but no codes?
CLi87
The check engine light on the console starts slow blinking steadily immediately after starting the engine but when I checked the codes in my Mercruiser 7.4 MPI it just gives me code 12 which should mean system is operational and nothing is wrong? Any idea where I should check to get the check engine light to stop blinking so that when something really is wrong then it'll blink
dingbat
In some older GM-based diagnostics, Code 12 can refer to a distributor signal interrupt, but on modern MerCruiser MPI systems with smart alarms, it is almost always related to the drive lube monitor
