PhrozeN_FisH
- May 25, 2008
- 30
I am trying to help a friend with his 150 Evinrude that the trim had become inoperative. I have tested connections through the relays according to service manuals, but both up and down tests pass, but when checking the ground side of the system it fails and states to replace the other relay. Both relays are new and had the same problem with old ones. When checking the terminals going to the trim motor on the PDP both terminals go hot whether up or down is pressed. I suspect that the diodes in the power distribution panel are bad and not providing a path to ground for the system. I can operate the trim motor by running +12v and ground to it directly.
Hope someone who has had experience with this could help direct me before ordering the PDP which is over $600.
Thanks for any help. Rod
