christianborys
- May 26, 2021
- 8
hey guys, I'm just looking for some advice because I'm really disappointed with what I've got.
This winter, I bought a 2000 four winns H170 with a Volvo 3.0 and I took it out last week. I had no problems apart from the engine stuttering when I tried to push out of a very low speed cruise into a higher speed. No matter how gently I tried to push the throttle, the same thing always happened. It felt like the boat had to stutter for 3 seconds before finally getting to speed.
And then, this weekend, I went for a ride on the lake and when I brought it back to the dock, when I shut the engine off, it sounded like it gasped for air before I heard a loud bang. I figured I flooded it because I didn't idle long enough and it would be fine in a few minutes.
But when I tried to restart it, this is the noise I heard.
I called some friends and they said the engine was probably flooded and the spark plugs needed to be cleaned or replaced.
But when I called the service tech over from the local marina to ask him to tow the boat back into the marina, right away he said that the starter was blown. He said that he'd worked on the same Volvo engine on two Glastron's and they'd had the exact same problem.
So he said they'd try to replace the starter without removing the engine but a day later, he told me that they couldn't get to the bolt in the starter without removing the engine.
They've quoted me $1,200 to remove the engine and replace the starter which makes me wonder if this is a common problem, if I bought a lemon, or what the hell happened. Any advice would be tremendously appreciated.
