Good morning, Just got a 2000 230 Searay with a 5.7 TBI and bravo outdrive, 230 hours, no prior knowledge of how it ran other than said, "it needs a tune up". The motor appeared to run rich and had high idle around 1300-1500, but would run decent up to full throttle at 4600 rpm. Next day it would not start. Pulled coil wire and it had spark. Pulled flame arrestor and It is getting fuel pulse from both injectors when motor was cranking, but no start. Pulled plugs, (wet and black) changed them, and it would start again, rev fine, but again had a high idle high of 1300-1500 and appear to run rich. Checked the throttle linkage and found the throttle cable was adjusted to keep it at a higher idle. removed the cable to allow throttle body to be fully closed and the when the throttle closed, the two injectors immediately shut off. Found it will only pulse the injectors and start with throttle cracked open. Once running, it will rev fine, and injector pulse pattern increases strongly with more rpm, but as soon as throttle body is closed and rpm drops below 1000 rpm, the two injectors will shut off and the motor will stall. If i open the throttle when it is stalling, the injectors will immediately turn back on and the motor will run again.
I have never seen anything like this.
Thank you all for your help and advice.
