$2000 prop toast, Need prop suggestions
Dmopar74
I have a 93 Bluewater Riviera 18' bowrider with 4.3 lx alpha one gen 2, and screwed up my prop on rocks. The thing is my prop is a power pitch pro shifting prop and replacement blades will run me $675. Also I have no idea which prop to pick because I have never had a normal prop on this boat. Boat is used for pleasure and towing tunes most the time
On another forum a 14.5x19 3 blade was suggested.
tpenfield
Mercury has a 'propeller selector' app on their web site that can ID a good prop & pitch.
achris
More fish than mountain goat
Insurance should cover rocked props...
jimmbo
Check to make sure the propshaft isn't bent. What were the pitches the shifting prop had? $675. was that per blade or for all three?
Dmopar74
The 675 is for all 3, which isn't had but more than I have right now. Figured I can buy an aluminum prop and run it till I can get new blades, then have the alum as a spare
The pitch was 17/23
jimmbo
So what is the WOT range for your engine and what rpm were you getting with shift prop? If it was at or near the top of range you could try a 23 in prop. If not then you need a different pitch for both the fixed pitch and the shift prop
