2000 Volvo Penta 5.7 Gfi with no spark
jackra_1
2000 Martinique 2600 5.7 Litre Gfi
Issue is no spark. Any ideas based on the following?
When I first got this boat the engine worked however no power to speak of.
Rotor contact badly burned.
Engine cranks and fuel injectors (two) work.
Engine in neutral and safety cut out disconnected.
I am unable to post the diagram !
Voltmeter shows 12 volts plus.
I am not getting 12 volts where the two wires go into the coil. I forget which one but one is supposed to have 12 volts and nothing with ignition on.
I have 12 volts all the way to the two relays mounted in front of Carb/injectors.
Also tachometer wants to read negative rpm when cranking.
Work done so far:
Replaced inlet manifold due to leak.
Replaced distributor. And rotor.
Replaced wires, plugs etc.
Replaced coil.
Replaced coil connectors.
Redid the instrument panel as it was falling to bits
so all gauges were taken out and now back in place.
alldodge
Welcome
What do you mean by
If you disconnected the kill switch then the motor doesn't get any power
Disconnect wire going to Tach to make sure Tach is not shorting out
jackra_1
The kill switch was bypassed basically in early testing. Engine turns over nicely.
I have already tried disconnecting the tach.
alldodge
Going to need more info.
The place I use to go to find parts break down is gone. I'm unable to find a Gfi but am able to find Gi
alldodge
ok, it's a Gi
The power to the coil comes from pin J2-32 (pink/white) on the ECM
If your not getting 12V at the coil then might need to get ECM tested
Best thing would be to check for codes and also check all fuses
To check for codes using a 12V resistor led or a digital meter with tone
Find the DLC and connect, insert jumper and connect led or meter. Turn key on and count flashes or tones
jackra_1
Thank you for that information. I was hoping it was not the ECM as I can not find new ones and good used ones are expensive.
I will do what you suggest. It will be a little while to obtain a 12 volt resistor type LED.
jackra_1
After doing some research on marine ECMs it seems that if the fuel pumps works then the ECM is good.
Will be a few days yet before I receive the led with a resistor.
jackra_1
My DLC has these rubber nipples. How do I jump across any of them?
jackra_1
Tomorrow I should be able to pick up the 12v resistor led . It has taken forever to have it delivered to my PO box.
Anyway I have checked all fuses and they are all ok. Same with all relays.
Assuming it is the ECM can anyone recommend a testing and repair service?
Also is anyone aware of a good used ECM for sale anywhere? Does the ECM have to be from a 2000 Volvo Penta 5.7 Gsi engine?
alldodge
jackra_1
Tried the diode and paper clip and absolutely nothing at all.
Will contact Bob now.
jackra_1
Will ship ECM off to Bob tomorrow.
Sorta hoping there is something wrong with this ECM and that it can be repaired. If there is nothing wrong with it hopefully an error code that will give me a clue.
jackra_1
Bob at ODB Diagnostics has the ECM now. I am hoping he can work on it early next week.
jackra_1
Bob called me just now.
Upshot is that the ECM is just fine however some error codes could be an issue. The voltage regulator on the distributor could be the problem. He says most new ones, and the one I have is new, are bad out of the box from China.
I still have my original so will use that as a start when I get the ECM back.
