2000 Yamaha 200 V6 Won't Pee
Keel01
Removed cowl and discovered the line I was told to use to "flush" the motor is not an opening. Can anyone tell me how to flush this type of outboard motor. Pees in the water, but I can't figure out the dry land flush.
Diver not boater, but would love to learn.
Thanks!
rodbolt
Re: 2000 Yamaha 200 V6 Won't Pee
use the muffs with full water pressure.
however if you have attached the hose to thye onboard flush holder you ran the pump dry, which means it may be time to inspect the pump.
on the port side of the lower cowl there is a small gray hose that attaches to the cowl. remove that hose and attach your garden hose to it, book says not to run it on that flusher but many do.
I always use the muffs.
when was the last cooling system tune up ?
