I have a motor that is stalling very badly. It has new filters, new fuel, it has over 50 psi at the vst when problem occurs. I also took the hp pump apart this morning and found one screen and removed it for inspection and it was perfectly clean. Is there a chance that there is another screen in there that could be clogged. Every once in a while it acts like it is going to run right, gets up to about 4000 rpms for a few seconds and will then stall back out. This morning I also unplugged the o2 for a minute and after I plugged it back up it ran good again for a short distance. I am a Master Honda Tech and would like to figure this out if all possible, but I know without the proper diagnostic equipment I may not be able to. I have been reading some of the post on here and it seems there is some great info to be found here. Thanks in advance for any help!
Scott
Scott
