So, drained the ol' single point today using Merc procedure. I had been reading up on this system here, and had got spooked a bit about the block draining fully. So, following recommendations here, I removed the block drain hose connections, no water came out. I used a long allen head wrench as the prod, and poked into the fitting, all the way to the block, no resistance at all and no scale came out. Moved the prod in a circle, nada-nothing-bupkis. When I pushed the prod in quickly it made a nice "ting" when it hit the other edge of the block. I kept track of how much prod went in to get the ting, it was definitely getting all the way in. All of the hoses and connections looked to be in great shape, Both sides of the block had exactly the same results.
This is not what I expected, but I guess I have to accept the results
Buttoned it all back up and ready for whatever is next.
