My motor is charging 16 volts and getting an alarm. I read that if you disconnect the ground wire from the reg and put your meter on the black ground wire and your other meter probe to the negative on the battery you should get 0 voltage. I'm getting 12 volts. I disconnected the main harness and still getting 12 volts on the black ground. I disconnected the main wire plug from the regulator and left the single wire plugged in and still getting 12 volts.. Any help would be appreciated. The new regulator does the same thing. 12 volts on the black negative wire..
