Hello,
I have a 2002 Sea Ray Sundancer 240 with the 5.0 efi and Bravo 3 out drive. Engine serial number is 0M090614 which I believe was manufactured in 2001. My problem: About two weeks ago I lost power at about 3000 rpm and I slowed to an idle; engine did not stall. Idled back to dock and was backing in and engine stalled once while going from forward to reverse; it restarted without issue. Boat sat in water at dock for two weeks and then wouldn't start or even attempt to. I hauled boat out and it's now on my trailer. What I've checked:
1- boat emits standard alarm when key is turned on and fuel pump? Can be heard running for about two seconds. Boats cranks fine but does not fire.
2- I've flipped the kill switch on and off during this procedure and it appears to be doing its job when off/on.
3- I've moved the shifter into forward while attempting to start boat and it shuts down when in gear so appears to be working.
4- I've disconnected grey wire from back of tachometer with no change.
5- there is no spark at coil wire to ground.
6- removed distributed cap which didn't look great, but again I have no spark to it so I'm not too worried about that yet.
7- I removed ignition coil and bench tested it and it appears to have correct resistance.
8- before I did any of the above I should note that upon attempting to start boat I see no fuel being injected, although I hear what I think is the fuel pump run for a couple of seconds like I've always heard it do. I tried some starter fluid with no results.
9- basically I'm missing two of the four (No spark, No Fuel, I'm guessing I have compression and timing)
10- I've looked at the main grounds, wires, and see no corrosion at all and they appear tight.
11- How do I know what ignition system I have ?? I have the round distributor cap and the ecm is mounted to the port riser
12- fuses under the dash all light up as good. Breakers are not tripped.
13- is there something that causes fuel to shut down when there is no spark from coil?
Hopefully I've provided enough for one of you experts to assist me.
Much thanks, Jeff
Much thanks, Jeff
