2001 Mercury 60hp Bigfoot
WesNewell
If your boat only weighs 500#, then you are way under propped and your engine is is maxing out rpm to the limiter with only a 15P prop. Merc prop selector suggest 25p for 500# boat and 300# load and speeds over 50 mph at 5800 rpm.
  • Usage: Overall good performance/0 ft
  • Engine Manufacturer:
    Mercury
  • Engine Type: Outboard
  • Engine Year: 2002
  • Number of Engines: One
  • Engine Family: FourStroke
  • Engine: 60 EFI 4cyl (995cc)
  • Drive / Gear Case: 40-60 HP 2-S Bigfoot, 40-60 HP 4-S
Details​
  • Calculated Pitch: 25.12
  • Calculated Weight with engine(s): 1,132.40 lbs
  • Calculated Engine RPM: 5,750
  • Calculated Boat Speed: 53.00 mph
harmanoff
    Mercury
  • Engine Year: 2002
Details​
damn just getting back onto this forum. My moter isnt a 4 stroke its a 2 stroke. would that make a difference?
JimS123
Yeah, you need a new prop. Probably a new engine as well. Its not suitable for your little boat.
harmanoff
Spoke to a Mercury Marine dealer yesterday, he didnt see any issues with having that motor on my boat, will be testing the WOT RPM to see if i need to go from a 15p prop to 17 or 19, the post above saying i need a 25p prop is way off base
harmanoff
I boat can handle up to a 90hp engine, the RPM at WOT i haven't figured out yet, have to replace a starter solenoid tonight when i get down there. From what i can guess at at WOT and motor trimmed out would be roughly between 5850 to 6000. hence why he said i needed a slightly bigger pitch prop but will know more details about it hopefully tonight!. My boat has the long transom not a short transom
