2001 yamaha t9.9
Jakem
Has anyone a clue were this wire goes. I'm either really blind or something. I didn't pull it off
A red wire with a fuse usually is part of the 12 volt supply to a ignition key switch.
Item #6 would be the fuse.-----Found inside the black rubber plug.
QBhoy
I’d have naturally though that was the charging outlet arrangement to trickle charge a battery
