Another issue I found is that if I pressure up the fuel system and turn off the key the system will lose pressure. Is the check valve in the fuel cell that is supposed to prevent fuel from flowing back out of the fuel rail causing the pressure to drop. Thanks in advance for any help!
3. A fuel system that drops more than 14 kPa (2 psi)
in 10 minutes has a leak in one or more of the
following areas:
• The fuel pump check valve.
• The fuel pump flex pipe.
• The valve or valve seat within the fuel pressure
regulator.
• The fuel injector(s).
4. A fuel system that drops more than 14 kPa (2 psi)
in 10 minutes after being relieved to 69 kPa (10
psi) indicates a leaking fuel pump check valve.
5. Fuel pressure that drops off during acceleration,
cruise or hard cornering may cause a lean
condition. A lean condition can cause a loss of
power, surging or misfire.
