2002 DP-SM 3868913 Prop Shaft Seal Replacement
bikker2001
I have a 2002 Volvo Penta DP-SM 1.95 3868913 outdrive that is leaking oil. I had it in the upholstery shop (heated) all winter and when I went to change the lower unit oil this spring there was very little oil in it and it was milky/cloudy. The bottom plug o-ring looked a bit chewed up. I've replaced the oil and the o-rings, but I'm not convinced that solved the problem. (I'm still watching it.)
My question is this, How do you change the prop shaft seals? I'm a decent mechanic, but is this something a shade tree mechanic like myself can handle?
Videos or step-by-step how-to's with pics would be very much appreciated.
dypcdiver
This subject has been covered several times on here, perhaps you might like to search for posts. You should get the Workshop Manual VPA 7743008 07-2003.
