Hello all: I have a 2002 johnson oceanrunner. I hadn't used it in 6 months as I was out of state working. When I came back, it ran rough. It kept cutting off, no doubt the gas was old. I thought if I burned off the bad gas, I could then put in good gas and it would again run smooth. Stupid me. Eventually, it was so bad, I managed to limp back to the dock.
The engine was completely dead. It wouldn't even try to start or kick over. the power trim didn't work, I had to manually loosen the screw to raise the tilt and trim. Now, the controls wont work, you get nothing. Is there a fuse somewhere?
I tried another battery directly to the outruner from the controls for trim in the outboard itself. Nothing as well. Is there a main fuse somewhere? The battery wasn't too dead, and I gave it a complete charge on my charger and it still wouldn't work anyway. Please help. thanks.
