2002 Mercruiser 6.2L Serial # - 0L678630
Been fighting this issue trying to figure out what is going on and now at a loss and need some help or advise. Motor starts really easy and sounds well idling, you cant tell anything is wrong until you put a load to it and open the throttle up. Upon full throttle I am only seeing 2100 RPM 10MPH max speed and backfiring, I should be seeing 4200 RPM at full throttle. I had a boat mechanic down and he thought it may just need a tune up, replaced all spark plugs and wires, distributer cap and rotor as well as the sensor that's under the cap, motor stayed the same and still running like crap. Did a fuel pressure test and have 43PSI even under a load. While out on the water the mechanic had his scan tool hooked to the ECM and noticed it was not advancing at idle it was running around 30 degrees and when you give it the throttle it would be somewhere in the 20's. He did make it advance and RPMs started to climb and boat started to run great but we received a really bad spark knock in return. Once we got back to the dock I had him do a compression test and didn't find anything there either
Cylinders
1 - 205
2 - 195
3- 195
4 - 195
5 - 195
6 - 185
7 - 200
8 - 195
Pulled the distributer out to check the gear and to see if the roll pin was intact and everything looked fine there as well
Injectors seem to be working as we pulled them off one by one as the engine was running and you can hear a change. They were also all gone through just last year. I am planning on pulling them all out Tomorrow and taking them in to have them looked at again and see if there is one or two that's not opening up all the way.
we are thinking it is possibly the ECM module which is a MEFI 3 that they don't make anymore and from what I am finding to be extremely hard to find one to just try out.
My question is are we missing something?
What are my options?
and where do I go from here?
Motor is in a 2002 Sport-craft 272 sportfish if that helps at all
I am really needing so options here as I am at a loss, Thanks in advance
Cylinders
1 - 205
2 - 195
3- 195
4 - 195
5 - 195
6 - 185
7 - 200
8 - 195
