2002 Seafox 182 Bayfisher Fuel Sender ??
Seafox182
We have a 2002 Seafox 182 Bay Fisher And cannot locate the fuel sender. Behind the center console there is an access panel but that is where the bilge pump is located. Underneath the center console seat there is no access panel but we are guessing that’s where the fuel sender is located. Any idea where this could be ?
dingbat
You will find the sender on the top of your fuel tank.
Do you know where In the tank is?
Most mfg put an access port to get to it. Mine is n the floor of the cockpit. Others, are not as thoughtful. You either have to remove the cap from the hull or cut a hole in the floor to access
