rosscopeeko
- Jul 24, 2006
- 57
Hi guys, i just bought a used 2002 15hp 2 stroke short shaft. I bought it without really seeing it run in water. It supposedly had low hours on it but was used in salt water only. It has a little rust on the exposed bolts here and there. Anyways, the guy dry fired it for me (not in water) and let it idle for a couple of seconds before i wanted it shut down. So anyways i bought it, got it home, and started looking a little closer at the motor. Here's my main problem: i can't get the shifter mechanism in reverse. It will click into forward without a problem, go back to neutral, but won't go into reverse when i push the handle towards the motor. Is there a trick to this?
