2003 5.0 gxi-d remote oil filter line / hose correct placement.
kccoe
I replaced my risers and manifolds and broke the mounts on the remote oil filter housing . I pulled it off hoping a machine shop could fix but they could not . I purchased a new housing but forgot to mark the two lines / hoses and which line / hose goes to which inlet port of the housing . Other words which hose is the return from the remote housing to engine block and which hose is "in line to the remote housing from engine block . . Any help or schematic would be appreciated. I sure don't want to reverse the lines .
Fishhead-1
The return hose is the center port on the filter housing hope that helps.
kccoe
I wish that Answer would help but, The filter housing is mark with in and out but the oil remote ports off the block or not. I unhooked the 2 hoses off the old cracked filter remote mount
dypcdiver
Pull the feed to the coil and turn the engine over on the starter, it will be obvious which is the feed to the filter.:)
