so i have had a rough idle problem,I have rebuild the carbs,fuel pump,replaced the trigger,stator, swapped cdm modules and now I cut the cyl 3 and cyl 2 kill switch wire blk/white and have noticed when I turn the motor off with the switch it stayed running cyl number 1 is still firing? is this normal? also while trying to time it seems to lose the spark-while looking at the timing light the timing seems to go completely off the numbers? like it goes out of time? when the ignition is turned off shouldn't the motor turn off.notre cyl 1 is still connected to the kill switch.
