2003 bravo 3 prop seal replacement
Status
Not open for further replies.
GA_Boater
I am new to the site, Hi All, I have a 2004 Rinker 262 Captiva w/ Bravo Three bought new, I have never taken off the outdrive or lower unit. I am trying to replace the prop seals, I have bought the tools and have attempted to remove the shaft. Is there anything else that holds the carrier on? I am turning clockwise to remove but does not move. Is there something that could be on, I have used a lot pressure to remove but doesn't budge.
My other issue is It appears the drive lube leak is coming from the lower unit housing, prior to taking off the props, the leak was coming out through the props, I removed the props, when I trimmed down the unit the lube came out of the lower unit housing.
The plan is to take out the prop shaft, if only I can get it off. My breaker bar is starting to route out the 1/2 opening of the removal tool.
Can anyone help me with this, Thanks
Please start a thread on your issue.
Closed.
Status
