Re: 2003 F115 "Hidden Filter"
there are no hidden filters.
each injector has a screen, there is a screen at the VST pump intake, a water trap befiore the low pressure pump and an inline filter between the low pressure pump and the VST.
there is no minimum compression figgure. if its suspect do a leak down test. its faster and more accurate than a compression test.
