2003 Johnson 25hp charging circuit?
thyNemesis
I recently purchased a 2003 Johnson 25hp tiller motor, model J25RSRR.
Does anyone know if this engine has the ability to charge a battery?
Battery charging was an option.------Anything on the starboard side of the motor with yellow wires ?------Batter charging kit is available.
Vic.S
That is the number for a 2004 model
battery charging kit available as an option on rope start models ( but fitted to electric start models)
The parts breakdown shows a stator coil though
If it is fitted there be a harness containing 3 sleeved yellow ( maybe with grey or blue stripes) wires coming from under the flywheel. Ths is the AC output to which the rectifier is fitted for battery charging
