No more boats
- May 4, 2023
- 70
OB new too me
2003 OX 66
2 stroke
250 HP
when I turn key switch first position should I hear fuel pump ? on this engine no fuse panel , located single in line fuse housed in a box labeled fuse box , but no fuse panel , some sort of breaker box with no breaker switch ? with series of wiring into it
VST. opened drain screw, only a cap full came out ?
Issue with key & kill switch ,
switch has a connect then disconnect issue , ( short ) not messing with it ordered new key 7 kill switch
IF I have too add fuel too VST will ball pump be the way to go pumping away or it fills while engine cranking with working pump ?
2003 OX 66
2 stroke
250 HP
