Just looking for some thoughts before I dig into this - I think I have the basics covered but wanted to double check.
I have twin 4.3's and independent gas tank for each engine. Noticed my starboard engine seems to burn more fuel than the port. Also noticed starboard exhaust smells rich. Engine runs fine, starts fine, idles fine and reaches max RPM just fine under load. At first I thought it was just difference in tank volumes and level senders (ignoring the rich smell). But now I have installed flow meters and think I can see it. Starboard engine wants to draw a steady 0.8 GPH at idle where the Port engine periodically draws 0.8 GPH, then drops back to zero for 15 seconds or so, rinse and repeat - this seemed to make sense with low pressure pump periodically refilling reservoir. I have not checked GPH under load yet, just idling in slip.
So I checked fuel pressure (all good) and looked at leak down of rail after shut down. Both engines were very similar - nothing stood out.
Both engines have the original MAP sensors from 2004. Figured changing that was part of the plan - just a major pain to reach. Anything else besides the MAP sensors? Dizzy caps, plugs, wire are all new.
Thanks for any thoughts you might have.
