More trouble with the project. Took it out again. After about 15 minute WOT run and maybe 30 minutes of fishing, start again. Starts easily, but if I give it gas, dies quickly. Or may die while idling for no obvious reason; almost feels like it is fuel starved. Pumping the primer bulb does not help.
Got it coaxed to life, made back to the dock OK. Behaved well on the run, but same problems during idle/off idle cropped up. No other obvious symptoms, except white spittle in carb throats (below; may or may not be related).
Wild guesses, roughly in the order of likelihood:
Water in the fuel
Fuel line blockage
Pump about to go out
Insufficient pulse to drive fuel pump at idle
Other things I might be overlooking, and how do I test for those?
Advice greatly appreciated. Thanks!
Water in the fuel
Fuel line blockage
