2005 3L TKS Intermittent Starting Issue
kidafa
Re: 2005 3L TKS Intermittent Starting Issue
Can you provide a link Dubs?
dubs283
you bet
its near the top of this very page, left side about eight inches from the top edge of your screen
it says "mercruiser parts" right above the "reply to thread" link
Don S
The best thing you can do, is go HERE and put in your serial number. Then you will be able to find the OEM part number for any part you want.
Then when you use this site to order parts, make sure the part you are ordering crosses to the OEM number. Solenoids can look the same but work differently inside.
I just used the above to find the OEM part number for your engine, put that number in the iboats parts search box and came up with THIS.
and YES, iboat ships to Australia again . Look HERE
kidafa
Thanks again Don for those links, that site where I search my serial is awesome.
Turns out as mentioned above the first recommendation for the solenoid was correct :)
