hey guys new here and i have searched and read alot prior to posting, heres my issue
i bought a 2005 24 ft sylvan pontoon with a 90 hp yamaha, it has 19 hours on her and shes sat quite awhile 2 yrs at best guess,. the first thing i did was drain the tank and flush out the fuel lines, pulled the carbs and the floats were stuck/gummed up on the bottom 2, top was empty and clean. i cleaned the jets and bowls, needle and seats. she starts right up and i took her out, surges on the top end @3500 rpms+ so i brought her back in and recleaned the carbs, found i missed the main jet on the bottom carb so i reassembled and resarted ok but now she wont idle so well, i took her out anyways to try to burn off some of the residual fuel and she goes full thottle but will only idle when the idle enrichment ajustment is closed. wont start in normal or open positions.. any ideas?
