2005 Yamaha F115 - Does this Make Sense
tomn3
Had my mechanic take the boat out for a sea trial and checkout a problem I'm having. Recently had the injectors cleaned and it ran smooth and quiet but only got to 4200 rpm. After about 15 minutes it wouldn't get past 3000 rpms and limped back to the marina.
He experienced the same symptoms on the sea trial. I have replaced all fuel system elements up to the motor(tank cleaned previously).
He said the pressure was ok at idle and when he throttled up it quickly dropped off to 9 psi or so. Sputtered and dropped to 0 then died. After waiting a few minutes he was able to get it restarted and back to the marina. He pulled the intake and VST and said it was clean, no issues. He did multiple checks that I can't list here.
He said the high pressure fuel pump was hot when he pulled everything(this was at least 15-20 minutes) and he wants to replace it.
My question is - does this make sense? I suspected the standard fuel issues and thought we'd find residue in the VST. If the rail can't hold pressure and the tank/filter is clean does it point to the pump? Again, it ran great previously for a short time but never achieved good rpms.
Thanks
SparkieBoat
Re: 2005 Yamaha F115 - Does this Make Sense
if the pressure is dropping to 9 psi, you got a problem. A high pressure fuel pump could cause this. I would make sure there are no clogged filters or lines first. Welcome to the over priced world of yamaha 4-strokes..cheaper to buy another motor sometimes.
99yam40
monitoring the fuel pressures at different points along with the vacuum on the supply should pin point you to where the problem is (high pressure pump, low pressure pump, filters/screens between them and inside, supply)
99yam40
Sparkie
did you ever contact Rodbolt directly?
Have not heard from him in awhile and concerned, so looking for a way to touch base with him
SparkieBoat
no I only contacted him through the forums...you could try looking up his Yamaha shop in Kill Devil Hills NC..
pine island fred
RODBOLT , TOM, hangs out at yamahaoutboardparts.com Is at JOES MARINA on WANACHESE N.C. which is close to MANETO Hope I have not lost a friend by telling you that. regards FRED
99yam40
Fred,
thanks for the info.
He has not posted there for over a month I think or maybe more.
Just trying to find out what has happened to him.
Hopefully he is on a long vacation or has moved south for good
SparkieBoat
he did talk about moving to the islands a lot. I think maybe Costa Rica..If you contact him tell him my alternator is bad....LOL..I wont tell on you Fred...
pine island fred
I do need to call him, he is 900 miles away and have not seen him for awhile. Will do it tomorrow. Cant see him moving He recently bought a nice house with lots of seawall in COLLINGTON. Also has a grown son and daughter in the area. His bride is from S AMERICA so he does spend time down there. FRED
99yam40
I sent an email to the shop he works at and I received a reply this morning
"Good Morning! Tom is alive and well! I will pass this email on so he can reply personally.
Jenny"
So it is good to hear he is doing OK
